I followed the instructions in the compile.txt,but Make gives errors. Will it
compile on a 64-bit CentOS 6.2 system? Am I missing something or is it just
not compatible?
Compile problem on CentOS 6.2 x86-64
I haven't tested CentOS in particular, but generally speaking, FreeFileSync
should run on all Linux distributions that support wxWidgets and boost. Can
you post the error message?
maybe gcc issue, you need gcc 4.6 to compile newer versions
