Mirror source drive to two backup drives how ?
DBenz
Hi, New to Free File Sync.
I have D data drive and its backup exists on two other drives O and a usb_HDD_018 as not all of D will fit on O , as O has data to keep I have had to delete from D to make space, so overflow is to the usb _HDD_018.
How can I get it to show me :-
1. what matching folder names exist and which drives they are on ?
2. what folders and files are unique to D
3. Backup D (mirror to O and usb_HDD_018 ) at same time, by which I mean it copies the data to either drive at the same time in that copy action.
If I were to compare D to O it would show me the folders that were not on O, I could then select them and copy contents to the usb, if I didnt want anything deleting from the usb, else I would use Mirror to usb. Would it do this as I am not aware it will copy multiple folders to same multiple folders on another drive, one has to do it 1 folder at a time which is impractical.
Could it in fact auto select the folders by matching addresses or do I have to browse for the multiple folders ?
Unless though it allows multi selection its going to be one at a time.
I might have it suggested to me to place all my folders into one, on D and on O then move them back out again, to have to do such can cause confusion, even a slight risk of data loss when the contents are many Gb.
The other day the drive I was doing this from had an I/O error (unable to be written to) so any movement wasnt possible anyway !
Cheers
DBenz
You are trying to do two syncs in one and that can't work. You will have to set up filters over two syncs to split up the content on D to the two locations. Splitting a backup to two locations is a problem because of the breadth-first sync FFS performs.
