Error on start FFS.
comandante1977
Hello.
Installed FFS 5.0. And I've got an error on start:
" GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is
not supported "
I have GTK+3.2.2 installed.
System - SLES11SP1.
Did you compile manually? If you're using the precompiled or Launchpad
version, then you'll have a GTK 2 dependency baked in. However GTK 2 is not a
requirement of FFS, but of wxWidgets only. So if you're able to compile
wxWidgets with GTK 3, FFS shouldn't casue any trobule.
> Using GTK+ 2.x and GTK+ 3 in the same process is not supported
Weird. Seems like a wxWidgets bug/issue.
comandante1977
All packages I compiled manually except wxWidgets, which I couldn't compile
with GTK3 (errors on make). So I installed wxGTK from repo.
As I can see now, wxWidget is still depends on GTK2. GTK3 support is only
planned in future release.
Just now found wxWidgets port to GTK3. Will try to recompile.
If wxWidgets will installed without errors have I recompile FFS?
FFS has a few "#include <gtk/gtk.h>" statements, which will include GTK3 on
your system, while the repostory version of wxGTK is built on GTK2. This is
the source of the mismatch.
Probably, in any way, just let the makefile resolve all dependencies.
comandante1977
Unfortunately still no luck with compiling wxWidgets.
I've got errors like this:
./src/gtk/dataview.cpp: In member function ‘virtual bool
wxGtkDataViewModelNotifier::ValueChanged(const wxDataViewItem&, unsigned
int)’:
./src/gtk/dataview.cpp:1683:38: error: ‘GtkTreeViewColumn’ has no member named
‘button’
./src/gtk/dataview.cpp: In constructor
‘wxDataViewCtrlDCImpl::wxDataViewCtrlDCImpl(wxDC*, wxDataViewCtrl*)’:
./src/gtk/dataview.cpp:2370:78: error: ‘gtk_widget_get_colormap’ was not
declared in this scope
./src/gtk/dataview.cpp: In member function ‘virtual void
wxDataViewCustomRenderer::RenderText(const wxString&, int, wxRect, wxDC*,
int)’:
./src/gtk/dataview.cpp:2454:53: error: cannot convert ‘GdkWindow* {aka
_GdkWindow*}’ to ‘cairo_t* {aka _cairo*}’ for argument ‘2’ to ‘void
gtk_cell_renderer_render(GtkCellRenderer*, cairo_t*, GtkWidget*, const
GdkRectangle*, const GdkRectangle*, GtkCellRendererState)’
./src/gtk/dataview.cpp: In member function ‘gboolean
wxDataViewCtrlInternal::get_iter(GtkTreeIter*, GtkTreePath*)’:
./src/gtk/dataview.cpp:3861:42: warning: cast to pointer from integer of
different size
wxDataViewCtrlInternal::iter_next(GtkTreeIter*)’:
./src/gtk/dataview.cpp:3964:42: warning: cast to pointer from integer of
different size
wxDataViewCtrlInternal::iter_nth_child(GtkTreeIter*, GtkTreeIter*, gint)’:
./src/gtk/dataview.cpp:4118:42: warning: cast to pointer from integer of
different size
make: *** Error 1
From what I found on Google so far wxWidgets seems not ready for GTK+3 for a
while to come. So the solution to build FFS is to use GTK+2 everywhere.
I'm right now downloading SUSE 12.1. If I get it to run on VirtualBox I'll
check out how to make FFS work.
comandante1977
Yes, it seems to be so. Let me know how it will work.
I will try for awhile to compile wxWidgets port.
comandante1977
Finally I compiled wxWidgets with GTK3 with --disable-dataviewctrl option.
Compiling FFS get an error:
/usr/local/include/wx-2.9/wx/event.h: In member function ‘void
zen::Grid::redirectRowLabelEvent(wxMouseEvent&)’:
/usr/local/include/wx-2.9/wx/event.h:3023:18: error: ‘virtual bool
wxEvtHandler::ProcessEvent(wxEvent&)’ is inaccessible
wx+/grid.cpp:1546:33: error: within this context
make: *** Error 1
comandante1977
In wx+/grid.cpp change
mainWin_->ProcessEvent(event);
to mainWin_->GetEventHandler()->ProcessEvent(event);
Error gone.
But new errors appears:
/usr/local/lib/libwx_gtk3u_adv-2.9.so: undefined reference to
`gdk_window_lookup_for_display'
`gdk_window_clear_area'
`GTK_WIDGET_REALIZED'
`GTK_WIDGET_APP_PAINTABLE'
`GTK_WIDGET_NO_WINDOW'
`gdk_window_set_back_pixmap'
collect2: ld returned 1 exit status
Tired for today :)
I didn't get any errors when compiling wxWidgets 2.9.3 development release
using
./configure --with-gtk --disable-debug --enable-unicode
Did you use the same instruction?
They deprecated this call in wxWidgets 2.9.3. I've fixed the source code
accordingly.
Generally I'll try to make FFS free from libgtkmm. Now with gtk3 on suse,
managing the makefiles and build instructions isn't worth the few lines that
can be rewritten using gtk directly.
comandante1977
using ./configure --with-gtk --disable-debug --enable-unicode Did you use the
same instruction?
Do you compiled with GTK3?
On my attempts compiling wxWidgets 2.9.3 witn GTK3 I've got next errors:
/Distr/wxWidgets-2.9.3/bk-deps g++ -c -o coredll_gtk_app.o
-I./.pch/wxprec_coredll -D__WXGTK__ -DWXBUILDING -I./src/regex
-I./src/expat/lib -DWXUSINGDLL -DWXMAKINGDLL_CORE -DwxUSE_BASE=0 -fPIC -DPIC
-Wall -Wundef -Wunused-parameter -Wno-ctor-dtor-privacy -Woverloaded-virtual
-D_FILE_OFFSET_BITS=64 -DwxDEBUG_LEVEL=0
-I/Distr/wxWidgets-2.9.3/lib/wx/include/gtk2-unicode-2.9 -I./include
-DGSEAL_ENABLE -pthread -I/opt/gtk/include/gtk-3.0
-I/usr/local/include/atk-1.0 -I/usr/local/include/cairo -I/usr/local/include
/gdk-pixbuf-2.0 -I/usr/local/include/pango-1.0 -I/usr/local/include/glib-2.0
-I/usr/local/lib/glib-2.0/include -I/usr/local/include/pixman-1
-I/usr/local/include/libpng15 -I/usr/include/freetype2 -DG_DISABLE_CAST_CHECKS
-DWX_PRECOMP -pthread -O2 -fno-strict-aliasing -fvisibility=hidden
-fvisibility-inlines-hidden ./src/gtk/app.cpp
./src/gtk/app.cpp: In member function ‘virtual bool wxApp::OnInitGui()’:
./src/gtk/app.cpp:236:57: error: ‘gtk_widget_get_default_visual’ was not
./src/gtk/app.cpp:238:62: error: ‘gdk_colormap_new’ was not declared in this
scope
./src/gtk/app.cpp:239:51: error: ‘gtk_widget_set_default_colormap’ was not
./src/gtk/app.cpp:255:73: error: ‘gdk_colormap_new’ was not declared in this
scope
./src/gtk/app.cpp:256:59: error: ‘gtk_widget_set_default_colormap’ was not
./src/gtk/app.cpp:263:77: error: ‘gdk_colormap_new’ was not declared in this
scope
./src/gtk/app.cpp:264:63: error: ‘gtk_widget_set_default_colormap’ was not
./src/gtk/app.cpp: In member function ‘virtual bool wxApp::Initialize(int&,
wxChar**)’:
./src/gtk/app.cpp:290:9: warning: ‘void g_thread_init(gpointer)’ is deprecated
(declared at /usr/local/include/glib-2.0/glib/deprecated/gthread.h:259)
./src/gtk/app.cpp:290:27: warning: ‘void g_thread_init(gpointer)’ is
deprecated (declared at
make: *** Error 1
A clear "maybe". I didn't specify a specific GTK version when building
wxWidgets, so I'd expect it to use the currently installed version which is
GTK3, even if wxWidgets says it's using GTK2.
How did you instruct wxWidgets to explicitly use GTK3?
Success! Compiles and runs on openSuse 12.1 x64 with wxWidgets 2.9.3 using the
default build instructions.
I don't get any GTK+3 vs GTK+2 errors during runtime, so it must be a pure
GTK+2 build.
comandante1977
While checking environment wxWidgets wants gtk+-2.0.pc pkgconfig file. I have
GTK+2 installed through YAST, so I haven't such file. GTK+3 installed from
sources, so I simply made a symlink to gtk+-3.0.pc. And in this way wxWidget
use GTK+3 libraries.
Here are the updated source files:
[404, Invalid URL: http://www.2shared.com/file/ZtM7bwgG/FFS_Source_v51_beta.html]
I also updated Compile.txt and included instructions for Suse. This should
work now for a pure GTK+2 build.
However I would recomment to use the older stable wxWidgets release 2.8.11 for
testing. The 2.9 series is still relatively buggy.
comandante1977
Today continued to try fix wxWidget GTK3 port to compile FFS in GTK3
environment.
Fix - in ../src/gtk/eggtrayicon.c gdk_window_lookup_for_display changed to
gdk_x11_window_lookup_for_display
_
`gdk_window_set_back_pixmap'_
Fix - in ../src/gtk/eggtrayicon.c gdk_window_set_back_pixmap changed to
gdk_window_set_background_pattern
Errors
are still presents. I'm not a developer at all. :)
As I can see some functions was withdrawn from GTK3 and how to migrate it I
dont know. :)
