How to install on other distros
hpm69
Hi there ! I'm quite ansious to start using FreeFileSync but did not find the
installation instructions for other distros, specially red hat.
Did anyone have installed it successfully on red hat ?
Thank you in advance ?
hpm69
I meant, have anyone installed it... ? this is what means ansious... :-)
If they have wxWidgets and boost, there should be no reason why FFS is not
working. The code is platform independent, so should work on all Linux
distributions that fulfill these preconditions. When in doubt, just test it:
Compile instructions can be found in "compile.txt"
