for the last years i worked with another snchronizingsoftware since I heard
about FFS a few days ago. At my tests with ffs I missed a Feature which made
my work with the other software much easier. Maybe I'm just to blind to see :)
I defined a lot of folderpairs to synchronize, but i don't want to synchronize
them all at the same Time. Sometimes I have to synchronize folderpair 1,3 an
6, samotimes folderpair 2,3 and 7. Is it in FFS possible to choose in a list
of folderpairs several pairs to synchronize and the rest not? For example with
a checkbox in front of every pair.
Choose which folderpair to synchronize
There is no direct support to temporarily disable folder pairs, but there are
a few workarounds:
1. The most obvious: create multiple configurations, each of which contains the subset that shall be sync'ed
2. Have one big configuration with all the folder pairs, and delete the pairs you don't want to sync. Do not save this change.
3. New with v5.0: Mark multiple folder pairs in the tree view and exclude them temporarily after comparison.
a few workarounds:
