How to customize the notify email that gets sent out?
steedt
I have looked everywhere but can not for the life of me see where I can edit or customize the email that goes out. I'd like to customize it a little instead of the default one. How do I go about doing that?
The email is currently not customizable. What would you change?
steedt
For instance I'm using Zapier to add the email to a spreadsheet and I just want 1 line to show up. The line that says what was updated. I see there are tools within Zapier I can try and use to format it, but just thought I would ask anyways. Also thank you for creating this wonderful program!!!!
