Is there a way to keep the file versioning in the same folder as the original one instead of specifying a different location ?
Keep revisions in same folder as original
You can, just make sure you exclude from the sync unless you want the version folder to also be synced to the to destination.
What I meant by this is:
Source\Data\File1.txt
Destination\Data\File1.txt
Destination\Data\File1 2021-05-18-0001.txt
Destination\Data\File1 2021-05-17-0424.txt
etc...
See that the versioning occurs in the original destination path, that`s what I want to achieve.
etc...
I see, I interpreted 'original' as the source of the sync. That can't work because the versioned files would then throw the syncing out of whack. They would be deleted upon another mirror sync, copied back to source if running two-way, and updating fails because it first versions the existing file before updating and fails because the file now doesn't exist in the destination. The filters required would be immense
Well I do not use mirroring, only one way sync, that`s why I was asking.
One-way sync is mirroring
Well I mean only update the destination with the new files.
If we could ad an .ffsrev extension for the versioned files we could easily filter them.
This will refrain us from using FFS for our purposes so we will have to look for an alternative until there a similar feature implemented.
Thanks for answering and keep up the good work
Have a great day
Have a great day
Ah I see! Hopefully you find something! FileHistory/Windows backup has been reliable as long and you aren't backing up to an external
Hi
I just started using the app.
Need similar functionality.
Have multiple backup hard discs which I would like now to merge into one new disc stack.
It would be really helpful for me when I would have different versions in the original folder.
Cheers
AdS
Cheers
AdS
Did you find an alternative? Have same requirement. ThanksWell I mean only update the destination with the new files.
Have a great day mhoude, 18 May 2021, 16:55
