Add FFS to Winget
alex
Hey,
Do you plan to release in the future FFS to Winget (https://github.com/microsoft/winget-pkgs) ?
Thank you
OLLI_S
I am also using WinGet to install applications and to keep my installed applications up-to-date.
Unfortunately FreeFileSync is not available on WinGet, so I requested it on GitHub:
https://github.com/microsoft/winget-pkgs/issues/57900
The official answer from WinGet was:
Blocked due to no silent install; The publisher requires the paid version to be able to perform a silent installation
It would be very useful to have FreeFileSync on WinGet, because I can install FreeFileSync with one little command:
winget install FreeFileSync
I also can update all my installed apps with one little command:
winget upgrade --all
I am a donor user of FreeFileSync for many years now and I really would love to see the donor version of FreeFileSync on WinGet!
Thank you!
OLLI
ArminW
I second this suggestion!
krige
I am using winget to install all my software. FreeFileSync is the only application I need to install manually by downloading the installation files from the web site. Please add it to winget!
khisel
I just discovered the absolute bliss of using Winget via the WingetUI and was very disappointed not to find FFS worked with it. After using Winget, I am slightly annoyed at apps that require downloading/updating. I love FFS, but this would be the cherry on top.
Nova_Max
This would be very useful
GeAd23
I hope this function would be added with the next update. Because I have support the project and can now use the Donation Edition. But now I want to install it over UniGetUI (WinGet), so it must support silent install. I don’t think it’s only a feature that you need for Commercial Use only.
John1234
It would be fantastic if FFS were in the database for winget. There are over 8,000 applications there some of which are direct competition that are available.
Winget search sync or backup
This command should show free file sync along with all of the other synchronization products.
GeAd23
This is a highly recommend feature for free and donation Edition to. So please change the program for silent install.
tigerguppy
This is the only reason I haven't switched to FreeFileSync on Windows. There's package manager support for FreeFileSync in Linux and MacOS but Windows is lagging behind without support in Winget.
therube
(To me, one uses a program because it works for them, not because some "package manager" supports it or not.
Never used Winget, or any "manager". Probably never would. I'd rather think & decide for myself, then offload it to some "manager" - even an auto-updater. Guess others are different ;-).)
Eh, WinGet and package managers in general are pretty great. Being able to load/update with software-agnostic CLI is awesome. Couple problems with FFS being on WinGet though:
- Silent/CLI install is a feature not available in the standard/free version
- Licensed software in WinGet would have to be the full-featured package with some type of key/licensing service to unlock features, which would require significant rework of the entire codebase.
