My main linux system is a Raspberry Pi 4 with 8GB RAM (which I operate from an iPad Pro with MagicKeyboard via xrdp and MS Remote Desktop).
Unfortunately, the downloadable linux binaries are from what I can tell x86 only (they don't even seem to be amd64, if the file app isn't indicating something wrong).
While you obviously can't cover everything, armhf and arm64 are in the mean time such common platforms, that for linux it really takes x86, amd64, armhf and arm64 to cover the most common installations, particularly since the source download isn't particularly friendly to compile (e.g. autoconf or something similar).
Wouldn't mind donating, but first the software has to be actually usable on my platforms...
[Feature Request] aarch64/arm64 linux binaries
I second this! arm64 binaries would be great
