section for synchronization
AlexFofo
I would like to know if we can have sections for synchronizations (in the left part)?
Thank you for telling me if it's possible...
If it's not, I would like to suggest you to add it.
I think it would be very practical and much clearer in the way you manage your synchronizations...
I image this as subfolders (named like the section) in the folder where we have our *.ffs_gui files...
and in the GUI it could look like this:
[last session]
sync1
sync2
sync3
-----sync_sav_DD-----
       |sync1
       |sync2
       |sync3
-----sync_laptop-----
       |sync1
       |sync2
       |sync3
-----sync_key_work-----
       |sync1
       |sync2
       |sync3
I think it would greatly clarify our backups...
Thanks for reading me
therube
(If you put your "code" in [ code ] blocks [ /code ], the formatting would be retained.)
(The spaces above are only there so that the code block is not live.)
[last session]
sync1
sync2
sync3
       |sync1
       |sync2
       |sync3
       |sync1
       |sync2
       |sync3
       |sync1
       |sync2
       |sync3
AlexFofo
thank you...
You can already group configurations by assigning a color:
AlexFofo
ah, yes! thank you, it will be already much better...
