Can't see COMPARE and SYNCRONIZED Columnsa
dehermens
When I select a task to run on the LEFT of the main screen, nothing shows up in the COMPARE and SYNCRONIZED windows. It used to show up there but it does not now.
Obviously you won't see any Compare results or proposed sync actions until you (have) run a Compare.
But, after selecting a sync configuration (in the top-left window) you should see the left-righ pair(s).
In the FreeFileSync (FFS) GUI, try (top left menu) Tools / Reset layout.
dehermens
BULLSEYE! That was it. The reset cleared it up. Thank you!
