Deleted files copied back?
lyonkster
I have been using FFS for a while with no issues. Recently I set up a sync from my PC to my NAS using two way sync. Now I am noticing that if I delete files on the PC, FFS wants to copy them back from the NAS to the PC, instead of also deleting them on the NAS. What am I doing wrong? I have resorted to using a mirror sync, but that is not what I really want to be doing. Thanks.
Did you delete the sync.ffs_db file on either the PC or NAS side? In this case FFS will (have to) behave like on the first sync and not be able to detect deletions.
lyonkster
Hi Zenju, thanks for the response. I am not able to find the sync.ffs_db file; in which folder should I be looking for it?
