One of my ".ffs_batch" files contains variable %date% in target directory, as
I want only to backup each 3rd day to unique destination (using Update mode).
However, when I launch FFS, it wont create that folder, and throw error
"directory does not exist".
Do I have to create batch script for this? It would be something like:
mkdir %date:~-4,4%-%date:~-7,2%-%date:~3,2%
Variable target folder (%date%)
Just ignore the error, the directory will be created automatically.
Choosing ignore the sync is running OK, but only once !
The second time you have to do compare and choose ignore again....
If this job is automated using the task scheduler how can I set default to ignore ?
