Runs okay within FFS program / Not as a task
jackdashack
I had a file in this folder, apparently a system file that was for example .849C2293-D346-4E56-8D6E-42412F2A707D
and of course FFS balked and said it's locked by another process. So in creating this batch I excluded it and then mirroring ran fine.
When I create a windows task and click on run I get the same message I used to get within FFS. Can't copy because it's a locked by another program. Do you know why FFS will run it and when testing the task it balks at that file I've excluded in FFS?
Hope that wasn't too cryptic. Not good at explaining here. ty jep
jackdashack
I found the answer. In the Tutorial Video the nice lady says in the video on Scheduling, that the Argument, which in my case is a "batch file" must have " " at each end, but apparently only if your batch name has a space. For example, [My backup_batch.ffs] (forget the containers) See that space after My? She says so it doesn't pick up it as 2 arguments begin and end it with quotes so it see's it at just one argument. My batch name had no spaces so I figured didn't need the quotes. According to her speech you don't. Well when I put quotes on my Argument, even though there were no spaces, it worked. I'll go with that and not worry about how she presented it.
The "lady" in the tutorial is a voice-over, reading out what the FFS author Zenju asked her to ...
The fact that you have to use quotes around a sync configuration filename that does not comprise spaces is very remarkable. Are you sure that there were also no spaces in the path pointing to the configuration file?
jackdashack
This is the name of my batch . . .
OneDriveSyncSettings.ffs_batch
My question is not about a space in the OneDriveSyncSettings.ffs_batch filename,
but about a the path preceding the filename,
e.g. a space in the Rootfoldername\Subfoldername part of
C:\Rootfoldername\Subfoldername\OneDriveSyncSettings.ffs_batch
jackdashack
In Task Manager the it appears the space you speak of might be there. I had a snip to show but I don't see an option to post an inline image. So I'll have to type it.
Action | Details
Start a Program "C:\Program Files\FreeFileSync\FreeFileSync.exe" "C:\Program Files\FreeFileSync\OneDriveSyncSettings.ffs_Batch"
Could not get that on one online. I see possible 2 offences. 1) is it the space between the words Program and Files on each the Start Folder and the Argument? or 2) the quotes with a space between the Start Folder and the Argument? or 3) both?
jackdashack
Also the Task says, Operator or Administrator has refused the task.
However, I change up some files, made sure they reflected in my Explorer, Ran the task and FFS copied them or mirrored my local drive.
It's the space in the full path, between 'program' and 'files'
That's why you needed double quotes
jackdashack
Okay thanks. Plerry has helped a lot to get me here. So you are saying I haven't over used the quotes, everything is okay as you see it? I can run this from Task Scheduler, I'm not sure I've seen it run every 10 minutes like the lady in the Tutorial Video says. I'll test that. But wondering about that result stated above. Operator or Admin has refused the task? May be that I can run it manually, but it is not running as a schedule. I'll check that. It does report it's running.
jackdashack
It appears that Warning about Operator/Administrator I mentioned above is not bogus. Something is stopping it from running auto. Manual, fine, auto, no?
