Task Scheduler: The operator or administrator has refused the request (Error 0x800710E0)
jackdashack
Was does this result mean in task scheduler? It seems to make the necessary changes in the destination folder if there are changes to the source folder? But what is this result? Is it something mis-stated in FFS or the Task Scheduler. Is it actually keeping FFS from running? When I manually run the Task it works. Maybe it's not working with Task Scheduler? I installed and created this FFS batch while logged in as administrator. In fact that's all I ever logon as, the administrator.
I created this task schedule by watching the FFS Tutorial on Creating a Task. Step b Step
Do you have any idea why? Comon' you smart ones you know you have an answer. No? ;)
