Suggestion / Bug: Filter . extension by default on Windows
BikeHelmet
Just a suggestion - it may be worthwhile to add *. as a default exclusion on Windows. While Linux, MacOS, and even earlier versions of Windows like WinXP were capable of handling these files, new Windows stumbles on them. Windows expects either a .extension or a blank filename, but never a file ending in a period. FreeFileSync happily created one or two of these when syncing from an old WinXP drive, but Windows was unable to comprehend what they are, so I now have some 0 byte files sitting around that are undeletable using any tool.
The solution is to reformat E drive, so instead I will just leave the undeletable files in their now undeletable folder and never touch that folder structure again. I'll immediately update all my FreeFileSync plans to exclude *. though!...
Just wanted to let the devs know so that they can set up the default configuration to be safer.
(Win10 Pro v21H1)
Well that's interesting! I wonder how Windows was even able to copy it over in the first place
Try this in an admin cmd window:
del "\\?\E:\Stuff\People\_Clients\xxxxxx\Dump from Dying WinXP Vista PC\C Drive\xxxxxx\My Documents."
Of course replace the xxxxxx with your redacted info
BikeHelmet
Heh... nobody claimed that Windows lets you do things that are smart or safe! They are 0 bytes, so I'd think it wasn't able to copy them over properly. It stumbled as soon as it made the filesystem entry that makes them show up as 0 byte files.
I didn't get to try that command, as I finally found a solution this morning. I had been trying to rename or delete it in cmd, powershell, explorer, notepad, notepad++, libreoffice, etc. - I finally stumbled across a program able to add to its file extension... 7-Zip. I don't know what it does differently, but an admin 7-zip file manager window was able to rename the files to .x, and then they immediately deleted as normal in Explorer. Yay, work-around discovered!
They're still very unsafe and annoying files, though! Win10 does not like them! (Probably Win7 onward, possibly Vista too.)
Giangi
earlier versions of Windows like WinXP were capable of handling these files, new Windows stumbles on them. Windows expects either a .extension or a blank filename, but never a file ending in a period. BikeHelmet, 22 Nov 2021, 12:08
Uhm... I just tried on an old virtual WinXP and I simply wasn't able to create a file ending with a dot!
I guess the original files have been created with a "3rd party" application or another OS...
therube
A file name ending with a dot (or even spaces) is perfectly legal.
That Windows itself may not deal with them nicely is a different matter entirely.
7-zip is a very useful tool.
(I just discovered that 7-zip can "see" .flv (media) files, extracting the audio & video portions.
I suppose that is "known" - but I never knew it.)
Windows Illegal Character Help
del "\\?\E:\Stuff\People\_Clients\xxxxxx\Dump from Dying WinXP Vista PC\C Drive\xxxxxx\My Documents." xCSxXenon, 22 Nov 2021, 15:57
Either this, or just use FreeFileSync (and delete manually)...
BikeHelmet
I guess the original files have been created with a "3rd party" application or another OS... Giangi, 23 Nov 2021, 13:01
That seems quite likely. The old drive had lots of radio software on it - much of that old software seems a little cobbled together, or at least it did when I dabbled with it. (AirMail, etc.) While recovering data I noted dozens of programs that I did not recognize - I would guess that the code in one of them lacks many sanity checks.
Ex:
http://siriuscyber.net/airmail/
