Creating New Entry Annoyance
fturtle
Using 11.14 and have a minor annoyance issue with it.
Every time I go to add an entry to the job list, it defaults to
"/users/public/documents"
instead of the drive I was working with.
As I just upgraded from 11.8 and don't know if the issue is related to FFS or to Windows 10
Just Realized that FFS 11.14 is not seeing the folders such as Pictures, My Documents, Music and such as they've been relocated to other drives using the move function in Windows. Not sure why this is the case but it could explain part of the reason it's defaulting to /users/public/my documents when creating a sync pair instead of sticking with the drive I was working with.
FFS seems to remember the last used path just fine in my tests. What exact steps does it take to reproduce this behavior?
fturtle
Seems that the 21H1 Update solved the problem through a Mandantory Reboot last night. Just checked and it went right to the folder/drive I was last working from and it did not jump to /users/public/documents as it had been doing.
Two possibilities as to the cause. 1st is I did not reboot after upgrading
2nd is that Windows forced the 21H1 Feature update on me overnight along with a reboot so it fixed what ever was happening
