Error compiling FreeFileSync 11.17 on Ubuntu (20.04)
xtradeb
Hi!
I'm unable to compile FreeFileSync 11.17 on Ubuntu (20.04). The previous version compiled fine.
This is the error I get:
mkdir -p /tmp/RealTimeSync_Make/ffs/src/rts/../../../wx+/
g++-10 -std=c++2a -pipe -DWXINTL_NO_GETTEXT_MACRO -I../../.. -I../../../zenXml -include "zen/i18n.h" -include "zen/warn_static.h" -Wall -Wfatal-errors -Wmissing-include-dirs -Wswitch-enum -Wcast-align -Wnon-virtual-dtor -Wno-unused-function -Wshadow -Wno-maybe-uninitialized -O3 -DNDEBUG `wx-config --cxxflags --debug=no` -pthread -fpie `pkg-config --cflags gtk+-3.0` -isystem/usr/include/gtk-3.0 -c ../../../wx+/image_tools.cpp -o /tmp/RealTimeSync_Make/ffs/src/rts/../../../wx+/image_tools.cpp.o
application.cpp: In member function ‘virtual bool rts::Application::OnInit()’:
application.cpp:86:87: error: no match for call to ‘(rts::Application::OnInit()::<lambda(const wstring&)>) (wxString)’
86 | logInitError(e.toString() + "\n" "Loading GTK3\'s old CSS format instead...\n");
compilation terminated due to -Wfatal-errors.
You can find the full build log attached.
Can anyone help?
Thank you!
Jhonny Oliveira
https://xtradeb.net
Fixed! Thanks for the report. You may download the FFS 11.17 sources again.
xtradeb
Thank you! It works.
