Open window in the same location as manual sync when using RealTimeSync
superluig164
I suppose this would apply to any command-line driven invocation of FFS, but anyways, I have two displays. Normally when I do syncs, I open them on the secondary display. However, when using RealTimeSync (I suppose it would also happen when using the command line) the window shows up on the main display, no matter what. Is there a way to use the window preferences from FFS to decide where to open the sync window for the command-line? This could perhaps be configurable with a checkbox in the settings menu. I would like for sync jobs to show up on the lower screen when they happen, just so I can see what's going on.
