Feature Request: hide/disable common warnings [SOLVED]
Darko
I have a shared drive which does not support Recycle Bin feature. Every time sync job is perfrormed, a warning is generated:
⚠️ Warning The recycle bin is not supported by the following folders. Deleted or overwritten files will not be able to be restored:
(the list of folder(s) is shown here)
I am aware of this, and it is by design that way, but it would be nice if we could permanently hide it or disable it for that particular sync task.
Thanks!
In your Sync Settings (F8), you have apparently chosen to use the Recycle-bin as your Delete Files method. So, obviously you get a warning that a recycle-bin is not available.
If you don't want to use the recycle-bin, in your Sync Settings (F8) simply select Permanent as your delete Files method. As that will not (try to) use the recycle-bin, you will also no longer get a warning that you don't have one.
Note that all Sync Settings are sync configuration specific and saved when saving that configuration.
So you can have different Delete Files methods for different syncs, without the need to manually change that setting every time.
Darko
Aha! Will fix this in the settings. Thanks!
