FFS prevents logoff / shutdown
bjohol
Platform: Windows XP SP3
Running silent ffs_batch with error handling set to ignore and trying to log
off or shut down while ffs is still running.
FFS shuts down silently but log off / shut down is prevented.
System event log contains event id 1073 User32 "The attempt to
{logoff|shutdown|reboot} failed".
Other processes respond to the logoff/shutdown request leaving the system in a
bad state until user logs off a 2nd time.
How can we configure FFS so that it terminates gracefully without interrupting
the logoff/shutdown process?
Thank you!
Best regards
Björn Holmgren
Thanks for the report! The problem is not fixable that easily, so it will be
tracked here:
[404, Invalid URL: https://sourceforge.net/tracker/?func=detail&aid=3295005&group_id=234430&atid=1093083]
Best regards, Zenju
rupertt
mmh, why does my machine not shutdown?
I created a batch job which the user clicks, instead of shutting down the PC.
FFS does sync, but then it just stays at the progresswindow of FFS.
What can i do to get FFS to shutdown the PC?
