I currently have a mirror job for my photos from my PC to Server, that
includes all camera files, .jpg / .mov / .avi
I now want to change it to exclude the .mov and .avi files and remove them
from the server side only.
I can set the filters for .mov and .avi but don't see how to get FFS to remove
these files from the server.
When I run Compare, they never appear on the right side for deletion.
Is there a way to achieve this?
Thanks.
Update Existing Mirror Job To Exclude Files
You'll need two steps.
1. sync all jpg / .mov / .avi
2. remove mov / .avi from server -> mirror sync these types with an empty folder as source, which will effectively delete them.
It is possible to merge both steps into a single configuration using multiple
folder pairs
folder pairs
Thanks for your quick reply, it's much appreciated - the empty folder trick
worked perfectly!
Thanks once again for your support and great software.
worked perfectly!
