Unable to build Freefilsync 11.20 on Ubuntu Jammy
xtradeb
Hi!
I'm unable to compile FreeFileSync 11.20 on Ubuntu (20.04). This version requires wx 3.1. Unfortunately, Ubuntu Jammy (latest) only has 3.0 available.
This is the error I get:
In file included from ui/file_grid_attr.h:12,
from config.h:14,
from base_tools.h:12,
from base_tools.cpp:7:
../../wx+/dc.h:15:10: fatal error: wx/bmpbndl.h: No such file or directory
15 | #include <wx/bmpbndl.h>
compilation terminated.
Can anyone help me reverse patch the code to work with wx 3.0?
You can find the full set of patches I was using up to Freefilesyncversion 11.18 here: https://launchpad.net/~xtradeb/+archive/ubuntu/apps/+sourcefiles/freefilesync/11.18-1~xtradeb2/freefilesync_11.18-1~xtradeb2.debian.tar.xz
Btw, I also had to reverse: c++2b. It doesn't exist in Ubuntu Jammy.
Thank you!
Jhonny Oliveira
https://xtradeb.net
bgstack15
It's buried in patch https://gitlab.com/bgstack15/stackrpms/-/blob/master/freefilesync/debian/patches/revert_zenju_aggressive_upstreamisms.patch. I should have put it in ffs_no_wx311.patch but I didn't for some reason. I should fix that next time. Search for 11.20 to see the few files that got updated in that patch for this release.
Does Ubuntu Jammy have g++-11? That's what I used (Devuan Ceres) to get c++2b.
xtradeb
Thanks @bgstack15!
I have imported all of your patches, made some minor adjustments, et voila!
You are totally right, c++2b is also available. I don't know what happened...
Once again, thank you very much!
