Bug reporting
supman8899
i use 11.20. if the source file name have a 'space' or a 'dot' at the last character of a filename then ffs will not work indicating chown failure on target. please fix this asap/
Error message?
supman8899
EPERM: Operation not permitted [chown]
and i am not allow to donate for a full edition as i am from singapore.
supman8899
it happens when i sync from main ssd of a imac-pro on macosx 10.14.6 to a synology ds3622sx+ raid0 drive. ssd has 4tb and snology AFP only shared has 177tb.
supman8899
problems occurs now with mirror function of new subdir on main ssd disk to be clone onto synlogy shared path.
supman8899
viewtopic.php?t=274 got it to work btw.
however, i still think it is odd that it worked if its copying to other disks while any AFP shared path fails.
EPERM doesn't seem to be FFS-specific, but more a restriction of the target file system. So workaround would be to turn off "Copy file access permissions".
supman8899
thanks.
i would like to donate but paypal say you do not accept donation or fee from singapore.
are you able to accept bitcoin?
supman8899
hello?
No
hspindel
I recently discovered the neat verify file switch in GlobalSettings.xml. Running into one problem with it. I turned on verify for most of my syncs, but there are a few where I don't want verify. So I created a GlobalSettingsNoVerify.xml with verification off. I then start ffs via a desktop shortcut. That shortcut has as its target:
D:\Program Files\FreeFileSync\FreeFileSync.exe" "C:\Users\howard\Desktop\Syncs\SyncEdriveDS412.ffs_batch" "c:\documents and settings\howard\roaming\freefilesync\GlobalSettingsNoVerify.xml"
The contents of SyncEdriveDS412.ffs_batch are:
<?xml version="1.0" encoding="utf-8"?>
<FreeFileSync XmlType="BATCH" XmlFormat="23">
    <Notes/>
    <Compare>
        <Symlinks>Follow</Symlinks>
        <IgnoreTimeShift/>
    </Compare>
    <Synchronize>
        <Differences LeftOnly="right" LeftNewer="right" RightNewer="right" RightOnly="right"/>
        <DeletionPolicy>Permanent</DeletionPolicy>
        <VersioningFolder Style="Replace"/>
    </Synchronize>
    <Filter>
        <Include>
            <Item>*</Item>
        </Include>
        <Exclude>
            <Item>\System Volume Information\</Item>
            <Item>\$Recycle.Bin\</Item>
            <Item>\RECYCLER\</Item>
            <Item>\RECYCLED\</Item>
            <Item>*\desktop.ini</Item>
            <Item>*\thumbs.db</Item>
            <Item>\download</Item>
        </Exclude>
    </Filter>
    <FolderPairs>
        <Pair>
            <Left>E:\</Left>
            <Right>\\DS412\homes\howard\edrive</Right>
        </Pair>
    </FolderPairs>
    <Errors Ignore="true" Retry="0" Delay="5"/>
    <PostSyncCommand Condition="Completion"/>
    <LogFolder/>
    <EmailNotification Condition="Always"/>
    <GridViewType>Action</GridViewType>
    <Batch>
        <ProgressDialog Minimized="false" AutoClose="false"/>
        <ErrorDialog>Show</ErrorDialog>
        <PostSyncAction>None</PostSyncAction>
    </Batch>
</FreeFileSync>
ffs runs and successfully synchronizes. When I click on the "Close" button I get a Windows popup that says:
Cannot write file "C:\documents and settings\howard\roaming\freefilesync\GlobalSettingsNoVerify.xml.87cb.tmp".
ERROR_PATH_NOT_FOUND: The system cannot find the path specified. [CreateFile]
Any idea what is wrong? Dismissing the popup doesn't seem to cause any problems, but it does seem to indicate a problem.
Thank you.
hspindel
I just noticed in the error popup that where it says "howard\roaming" I would have expected "howard\AppData\roaming".
Perhaps that's a clue to the problem?
hspindel
Umm, yes, the missing "appdata" was causing the problem.
But it's missing in my invocation line posted above. When I fixed the invocation line, everything works great. Sorry I didn't notice the discrepancy, but posting here is probably what caused me to find it.
So ignore all the above!
Don't hijack threads in the first place, but definitely don't fill a hijacked thread with user error
hspindel
Didn't realize I hijacked a thread. I thought this was a general bug-reporting thread. That's what showed up when I searched.
Narziss70
Comparison results panel collapses to a sliver after restart; expanded state not persisted
Version: 14.11 (Donation Edition)
OS: Linux (path: /home/luca/)
Steps to reproduce:
Open a configuration (e.g. local folder ↔ SFTP remote).
Run Compare.
The bottom comparison results panel shows only a tiny grey vertical rectangle (collapsed state).
Double-click the rectangle → the panel expands and correctly shows the file list (e.g. 1 file to sync).
Click the small triangle next to the sync buttons → "Save as default".
Close FreeFileSync and reopen it with the same configuration.
Expected behaviour:
The comparison results panel should remain in the expanded state (showing the file list with unchanged/synced counts) after restart, since the layout was saved.
Actual behaviour:
The panel is collapsed back to the tiny grey rectangle. The "Save as default" action does not persist the expanded state.
Screenshot attached.
Comparison results panel collapses to a sliver after restart; expanded state not persisted Narziss70, 06 Sep 2026, 09:50
Fixed this and other GUI glitches caused by the recent wxWidgets update:
https://www.mediafire.com/file/idq586abikeupdv/FreeFileSync_14.12_beta_Linux_x86_64.tar.gz
Hannes_R
Hi, I have a vibe-coded build script to build FFS on Raspberry Pi OS. It stopped working with 14.12.
The agent has identified the issue and created a new patch for my script (build is still running). According to the agent, it is a regression, so I wanted to report it:
Linux build regression in 14.12: zen/string_traits.h fails with wxWidgets 3.3.3 due to ambiguous wxCStrData conversion
Summary
FreeFileSync 14.12 fails to compile on 64-bit Raspberry Pi OS when built with wxWidgets 3.3.3.
The failure is in zen/string_traits.h. wxString::c_str() returns wxCStrData, which is convertible to both const char* and const wchar_t*. The new 14.12 overload-based character-type deduction is therefore ambiguous.
FreeFileSync 14.11 contained a HasConversion<S, Char> implementation that handled this exact wxString/wxCStrData case correctly.
Environment
FreeFileSync: 14.12 source packageOperating system: Raspberry Pi OS / Debian 13, 64-bitArchitecture: aarch64Compiler: GCC / g++C++ language mode: -std=c++23wxWidgets: 3.3.3libcurl: 8.22.0libssh2: 1.11.1
libcurl 8.22.0 builds successfully and is not involved in the failing translation unit.
Actual result
Compilation fails while compiling application.cpp.
Compiler output:
In file included from ../../zen/string_tools.h:11,
from ../../zen/i18n.h:9,
from <command-line>:
../../zen/string_traits.h: In instantiation of
‘class zen::impl::GetCharTypeImpl<wxString, zen::impl::StringType::class_>’:
../../zen/string_traits.h:60:41: error:
call of overloaded ‘conversionType(wxCStrData)’ is ambiguous
using Type = decltype(conversionType(std::declval<S>().c_str()));
The ambiguity arises because wxCStrData can convert to both:
const char*
const wchar_t*
The 14.12 source defines both corresponding overloads:
static char conversionType(const char*);
static wchar_t conversionType(const wchar_t*);
Expected result
FreeFileSync 14.12 should compile successfully with wxWidgets 3.3.3, as FreeFileSync 14.11 did.
Regression details
FreeFileSync 14.11 used independent conversion checks and deliberately preferred wchar_t:
template <class S, class Char>
class HasConversion
using Yes = char[1];
using No = char[2];
static Yes& hasConversion(const Char*);
static No& hasConversion(...);
public:
static constexpr bool value =
sizeof(hasConversion(std::declval<S>().c_str())) == sizeof(Yes);
using Type = std::conditional_t<HasConversion<S, wchar_t>::value, wchar_t,
/**/ std::conditional_t<HasConversion<S, char>::value, char, void>>;
This is especially notable because the FreeFileSync 14.11 source comment specifically mentions that wxString::c_str() returns wxCStrData and is implicitly convertible to both pointer types.
Suggested fix
Retain the FreeFileSync 14.12 StringType class/view/C-string refactor, but restore the non-ambiguous conversion test for StringType::class_.
For example, add the following helper in namespace zen::impl:
class HasConversion
using No = char[2];
public:
Then replace this FreeFileSync 14.12 line:
with:
The conversionType() overload declarations can then be removed.
Workaround
A local patch restoring the FreeFileSync 14.11-style conversion test resolves the wxCStrData compiler error and allows compilation to proceed past this point on aarch64 Raspberry Pi OS with wxWidgets 3.3.3.
Update: Applying the HasConversion-based workaround resolves the original
wxCStrData ambiguity. The build now progresses substantially further, including
compiling application.cpp and multiple afs source files.
Compilation later stops at a separate FreeFileSync 14.12 compatibility issue:
libssh2_wrap.h references LIBSSH2_ERROR_STORE_OVERFLOW, which is absent from
the official libssh2 1.11.1 headers used by the build.
You need wxNO_IMPLICIT_WXSTRING_ENCODING.
Hannes_R
Confirmed, thank you.
Adding -DwxNO_IMPLICIT_WXSTRING_ENCODING to the FreeFileSync Makefile C++ flags resolved the wxCStrData ambiguity without patching zen/string_traits.h.
FreeFileSync 14.12 now builds and links successfully on aarch64 Debian 13.6 (trixie), using the stock Debian GCC 14.2.0-19, wxWidgets 3.3.3, libcurl 8.22.0, and libssh2 1.11.1.
I had previously applied a local string_traits.h workaround, but removed it for the validation build. The build succeeds with the define in place.
