I used to use a program that if you used source: F:\ and destination: G:\ the program would Sync the drives root and all directories/sub directories. But when I try using the above in FreeFileSync, I get an error message that says:
Cannot set directory lock for "F:\".
Cannot write file "F:\sync.ffs_lock".
Error Code 5: Access is denied. (CreateFile
If I choose a source directory on F:\ and an Existing dir on G:\ , it works as expected.
How can I Sync the entire drive, without manually adding and creating all the directories?
Can't Sync drive to drive?
The message seems clear enough: you don't seem to have the proper rights to write "F:\sync.ffs_lock".
Did you try running FFS with Admin rights?
Yes you are right. Running as Admin solved the problem.
Also, if you run the synchronization using the batch file created by FFS, then you can't "Run as Admin" because this option is not available in the right-click menu.
What you need to do in that case is to set the FreeFileSync program itself to run as Admin, not the batch. To do so:
- Go in the folder where FFS is installed (on my computer it's C:\Program Files\FreeFileSync\)
- Right click on the FreeFileSync.exe file (the one with the two green arrows)
- Properties
- Compatibility tab
- Check the box "Run this porgram as an administrator"
- Click Apply
- Click Ok
Now you should be able to double-click the batch file without having the error you mentioned.
- Properties
- Compatibility tab
- Click Apply
- Click Ok
