Versions folders per synchronization task?
Backitup
I'm a returning FFS user after many years since I last used it and I'm now finding my way how to configure it.
I created about 20 tasks for various purposes and I wish to apply versioning. However, I wonder if there's a way to keep the backed up files in an easy to retrieve way, per backup task, that is to have a directory where the versions of each task would be kept. This would be enormously helpful in identifying to which task the version backups relate.
You can do that, it's already implemented.
Backitup
Thank you. Hopefully I'll manage to see it in action once I finish my configuration!
