If I open 2 separate instances of FFS ad run two different jobs (one runnig job "Yellow" and one running Job "Green") , the field "Last Sync" is not consistent between the two instances.
It seems that this field is saved on program closing/shutdown,
Therefore the "Last Sync" field of the first instance that I close is lost.
Is it possible to save/read/refresh this field (for all the listed jobs) on every sync start/end ?
Thank you
MAX
