I just installed 11.22 and suddenly I'm getting the above error when I try to do a sync. I don't see anything in the forum here that affects that, and everything I see in web searches seems to be based on npm. This is macOS Monterey (12.4).
UPDATE: I just went into FreeFileSync.app in the Terminal and ran
sudo ./Contents/MacOS/FreeFileSync
and it worked fine. I'm sure that tells us something important, probably about permissions somewhere, but I don't know what that something is.
EACCES: Permission denied (UPDATED)
I am on LinuxMint I too was getting this error and this worked for me:
Try this, fixed it for me
sudo chown -R username path
Example:
sudo chown -R emanuel /home/emanuel/test/
Example:
When are you getting this error? When you open FFS? When you start a comparison? When you start a sync? Only on a subset of data in a specific location?
Hi @xCSxXenon, I was getting the error when trying to do a comparison/sync.
I have an external ntfs drive with all my data, that I was trying to move to my mdadm raid 6 ext4 box when I was getting the error. After I did the above sudo commands I was then able to use FFS to transfer the data as intended without the error.
Mac OS doesn't support NTFS volumes natively, are you sure it is NTFS?
Ya might have missed it on my original post, I am using LinuxMint. :)
Oh, I wasn't responding to you at all then. I was responding to the OPxCSxXenon
Ya might have missed it on my original post, I am using LinuxMint. :) bakebeans, 30 Sep 2024, 18:24
