I'd like to have it disabled so I can see the results of the synchronization when getting back to the PC in the morning.
I couldn't see an option for that, except the checkbox that's on the bottom of the batch job window, but you can't really uncheck it if it auto closes on completion. Moreover, even if I could tick it off, I'm not sure it would apply the setting for the next instances of this job.
Is there a dedicated setting for that somewhere ?
FWIW, I just upgraded to version 11.23. Until now, this checkbox has always been ticked off by default.
I'm pretty new to FFS and I'm sorry if this is an obvious issue.
Thanks for any guidance,
Roy
Disabling the auto-close checkbox in the batch job window ?
When you saved the batch job, there was a checkbox to auto-close. Just re-save it without that box checked
That's pretty much it. Thank you very much.
