At compilation I receive an error
/usr/lib/gcc/x86_64-pc-linux-gnu/4.3.4/../../../../x86_64-pc-linux-gnu/bin/ld: i386 architecture of input file `./.libs/libuuid.a(uuid_str.o)' is incompatible with i386:x86-64 output
./.libs/libuuid.a(uuid_str.o): In function `fmtint':
uuid_str.c:(.text+0xc9): undefined reference to `__umoddi3'
uuid_str.c:(.text+0xf4): undefined reference to `__udivdi3'
collect2: ld returned 1 exit status
make[1]: *** [uuid] Error 1
make[1]: Leaving directory `/Data/Soft/FreeFileSync/Sourcecode_v3.7/shared/ossp_uuid'
make: *** [osspUUID] Error 2
My system Linux Gentoo.
wxWidgets 2.8.11
Forgive for my English :)
Compile error
OSSP_UUID has been replaced with v3.8. So it isn't worth the trouble anymore
as I'm using boost/UUID instead.
1. Replace file guid.cpp by [404, Invalid URL: http://www.file-upload.net/download-2593065/guid.cpp.html]
2. download boost package (www.boost.org) and place it into "shared/boost_1_x" folder. Actually the files required by UUID are sufficient.
BTW: The error above is becaus it is using object files compiled for 32-bit. A
"make clean, make" for OSSP_UUID might help as well.
Now I try to compile version 3.8.
Result:
http://paste.org.ru/?xh6v9j
Thus wxGTK-2.8.11.0 it is installed.
Result:
I am sorry, it I was inattentive...
In these logs - eselect wxwidgets - all solves.
The problem is solved, all is started and works!
Thanks for a fine product!
New problem - after the launch of "Compare", a comparison of folders occurs,
but at the end of the program crashes with the message (in console):
"Terminate called after throwing an instance of 'Gtk:: IconThemeError'"
With v3.8 there are icons shown for each file using GTKMM. I can't say what
the problem is in this case. For a workaround, setting "ShowFileIcons="false""
for both sides within GlobalSettings.xml should help.
The crash is probably due to an uncaught exception "Gtk:: IconThemeError".
I've patched the icon buffer so that it should continue to run properly:
[404, Invalid URL: http://www.file-upload.net/download-2629200/iconBuffer.cpp.html]
Just replace this file and comile again.
Yes, thanks, now all work fine
Continuing the theme. Version 3.9:
http://paste.org.ru/?srly0g
The compilation procedure has changed with v3.9, see the updated Compile.txt.
Unfortunately, with established boost v1.41.0 - the same error...
http://paste.org.ru/?hfl2f9
Boost::uuid is available not before boost version 1.42. But with regards to
bugfixes to the threading api I highly suggest compiling with the newest
version 1.44.
version 1.44.
Thanks, really, now all is compiled, but at start attempt:
"A segmentation error"...
I had the same issue. Please do a clean-up of boost before installing it:
./bootstrap.sh --prefix=/usr/local/ --with-libraries=thread
sudo ./bjam --clean install
sudo ./bjam install
sudo ./bjam install
It would not be desirable to litter system with manual installation instead of
use of the manager of packages... While I will use 3.8, something is possible
in following versions will dare...
> litter system
You can use any other directory you like by specifying a different prefix.
> instead of use of the manager of packages
Problem is that the boost package is quite outdated on Ubuntu
C the new version I again update this theme :)
Now so:
http://paste.org.ru/?ei58r5
boost-1.44.0, wxGTK-2.8.11
With what the present error can be connected?
Now so:
> Warning: No config found to match:
This flag is causing the problem: " --static=yes"
Removing it from makefile should fix the problem which is that you try to
compile against a flavor of wxWidgets you have not built.
My bad, Compile.txt and Makefile do not correspond, I'll update Compile.txt
accordingly.
accordingly.
Thanks for the help and for the best program!
All has turned out.
Still wanted to ask about one moment. If the program is started not from SUDO
sometimes it takes off for time of process of synchronization and even more
often - at the moment of its termination. In the console thus:
Gtk:ERROR:gtkfilesystemmodel.c:746:gtk_file_system_model_sort: assertion
failed: (r == n_visible_rows)
All has turned out.
A quick google search revealed that quite a number of other applications
suffer from this issue. But I couldn't find any explanation how this can be
triggered or reproduced. So it seems to be a bug within GTK. GTK itself is
used by wxWidgets. So I fear there is not much I can do in my application
code. But to be sure I'd need a testcase describing how this behavior can be
reproduced. On my Ubuntu 32 bit machine this assert was not triggered (be it
with or without admin rights).
I had the same problem.... Could you please update the make file, so people
newbie like me would not have the same problems.
