File does not contain a valid configuration
gogreen1
I'm getting this error message after updating to 11.25. Never happened before. Any ideas why and how to fix this?
FFS is checking for correct file extensions: ffs_gui, ffs_batch
Revert to 11.24 and see what happens
Revert to 11.24 and see what happens xCSxXenon, 11 Sep 2022, 14:06
There's no need, this is due to the following change:
FreeFileSync 11.24 [2022-08-28]
Require config type and file extension to match
therube
Could explain that further?
Are you saying that if you had a
"dumy.ffs_real"
its' Commandline is now required to reference, dumy.ffs_batch, rather then some arbitrarily named, "test.ffs_batch" ?
No, it means weird stuff like the following will fail now:
• Create a .ffs_gui file, and give it a .ffs_batch extension
• Create a .ffs_gui file, and save it as a file without any extension
