FFS 11.25 Won't sync between ext4 and FAT32
uri2510
ffs tells me that it can'T sync my folders and files from a ext4 filesystem (Linux Mint) to an fat32 filesystem (usb stick). It tells me to use chown (change owner) but that does not work on fat32, because fat32 does not know any permissions. How can I sync between these two filesystems? Is there any switch I have to use?
Thanks in advance for your help
ulf
uri2510
Google translate:
I found the solution myself:
Under
Extras - Options - uncheck Copy file permissions
