How do i save file marking?
naary
hello
I synchronize some of the files in a certain folder, and mark from there what I want to synchronize. How do I save this for next time, so that I can sync only what I marked [with 'v' in the check boxes], so that I don't have to make a 'v' mark every time I resync?
In FFS, run a Compare.
Then, one by one, select a file you want to be synced, right-click on that file and choose to add that file to the Include Filter.
Or, select multiple files you want to sync (select a fist one, and then add more via Ctrl-click) right-click on any of those files and choose to add those files to the Include Filter.
And make sure to save your sync configuration, so you can recall it for the next time.
Inclusion / exclusion filters are for you
naary
Thanks to the helpers.
I managed in the end with Inclusion / exclusion filters.
I didn't succeed by ticking a checkbox, then saving, it didn't save the last action for me.
