There is a setting to specify what to do when deleting or modifying files.
But this setting is applied to both, local and remote sides.
When using e.g. SFTP there's usually no RecycleBin available remotely, just locally.
So I suggest to separate the setting for local and remote side so I can activate the use of RecycleBin locally, but having it deactivated on remote side.
Feature Request: handle RecycleBin differently for remote side
