Versioning Only
theleetbeagle
This may be a dumb or obvious question, but is there a way to have a script set up that doesn't backup everything to a new location, but instead just watches for changes and does a Versioning move?
Then no, you can't do what you're looking at wanting to do
Two sync jobs could do it:
1. Regular sync to some folder X on the same volume that will receive the versions in folder Y.
2. Sync from <empty folder> (just leave the source path empty in FFS) to X with versioning enabled to Y on the same volume. This will *move* the files to the versioning folder instead of copy (because they're on the same volume).
RTS could target simply .cmd script that just calls the two sync jobs in order.
But if X is containing the versions and then you are syncing an empty directory to X, don't the versions get deleted?
X should be located on the same volume as the versions, but not contain them.
I see that now! That would work. Essentially mirroring the data to a folder then mirroring an empty folder to that same folder, deleting the files, thus triggering the creation of versions.
Another possible concern, this means it will have to sync and delete all of the contents in the source folder, could be a lot of wasted time and write endurance depending on the source data. Really should use File History, it's built-in and is amazing to have right-click restorability
Another possible concern, this means it will have to sync and delete all of the contents in the source folder, could be a lot of wasted time and write endurance depending on the source data. xCSxXenon, 15 Dec 2022, 17:47
Ah, you're right.
