Hello, how to delete entries that have become useless for the choice of source and destination.
Thanks.
Delete entries that have become useless for the choice of source and destination
By "delete", I'll take it that you want to remove them from the listing - temporarily, rather then physically deleting the files from disk.
Highlight the file(s) you want to ignore, & hit the <spacebar>.
For an entire tree, right-click on the directory-name itself (not on a file name), & select, Exclude temporarily.
(Even though it says, Space, that will not work.)
I was thinking of removing the drop down entries for choosing folders. But, thanks to you, I realized that it was enough to select an entry from the list and press DEL.
Thanks.
Thanks.
