Linux installation of FreeFileSync versions higher than 11.16 for a regular user (i.e., a user without administrator pri
robix
There are three types of accounts in Linux Mint 20:
Custom
Administrator
Desktop user
During installation of Linux Mint 21.0 XFCE user type "Custom" was created as the default, but it generally plays the role of administrator. I gave it the name "privileged-user".
As usuall after an istallation, I've created another user (name: "regular-user") of "Desktop user" type. User "regular-user" does not have administrator privileges, so it is much more secure type of account.
FreeFileSync can be installed in two ways: for all users (requires root privileges) or locally ("for the current user").
When trying to run FreeFileSync_11.29_Install.run locally, for current user "regular-user" I have:
Accept the FreeFileSync license terms? [y]es, [n]o, or [s]how: [y/n/s] y
Sorry, user regular-user is not allowed to execute '/usr/bin/sh -c echo $HOME' as regular-user on my-rig.
HOME environment variable is not set for user "regular-user".
<Press a key>
Of course, environment variable "HOME" was set for "regular-user":
$ echo $HOME
/home/regular-user
After typing the command
in the terminal for the user "regular-user" the result is an empty line.
It looks like the installer executes
gets an empty line and assumes $HOME is not set.
For user "privileged-user", executing
yields non-empty $HOME: "/home/privileged-user".
So for the user "privileged-user" FreeFileSync_11.29_Install.run is OK.
Hence, you can install FreeFileSync 11.29 for current user only if that user has administrator privileges.
There is a fix: just type for the user "regular-user" in the terminal (note the ' character)
/usr/bin/sh -c 'echo $HOME'
and the result is "/home/regular-user", no administrator privileges are required.
The last version of FreeFileSync that allowed local installation for a non-administrator user was 11.16.
For version 11.17, the changes are described as follows
Show per-file progress in percent when copying large files
Log app initialization errors
Fixed uncaught exception after installation
Defer testing for third-party buggy DLLs until after crashing
Consider ReFS 128-bit file ID failure states (Windows)
Refer to volume by name: support names including brackets
Support local installation with non-standard home (Linux) <--- the "/usr/bin/sh -c echo $HOME" command was probably added here
So please consider for the next version of FreeFileSync change
to
robix
Sorry, the post title was truncated. The full title is
Linux installation of FreeFileSync versions higher than 11.16 for a regular user (i.e., a user without administrator privileges) is impossible (proposed fix)
There seems to be something else going on. FreeFileSync is executing something like:
echo $(sudo --user regular-user sh -c 'echo $HOME');
Does this return the correct HOME path on your system?
robix
Thank you for the clarification.
No, executing
$ echo $(sudo --user regular-user sh -c 'echo $HOME');
returns
But your post points out the problem. The command uses the "sudo".
The user "regular-user" is not a member of the "sudo" group (as it should be), so the entire command fails and returns an empty line.
Of course, a "privileged-user" can use "sudo", and the command is executed properly.
Fixed!
FreeFileSync 12.0
Don't require sudo for non-root installation (Linux)
robix
Great news, thanks.
