I don't know if it is there already in the software or at least I don't know how to do, hence help would be welcome.
When I sync across two PC in my network, the computer where I started the Sync shows the last sync history. If I go to other PC and start the sync there, it does not show that the sync was done on another PC. It shows the old sync history on that computer.
Where can sync the log file to show the same sync history on both or all network PC?
Sync history across computers
They are stored locally only. You could sync the log location I suppose, but it won't update the 'last sync' column. You'd have to sync the "GlobalSettings" file between the two also. Who knows if that will work. You should try and then report back lol
