Compare Synch
When I run a Compare on two folders. The folders are on different external hard drives. Compare shows that the files only exist on the right side, but using Finder on the MAC, clearly shows the files existing on both sides. Why does FreFileSync tell me the files are not there?
Your locations are probably not correct or your filters are not correct
