how can I set the minimum idle time in RealTimeSync when I start it as a Windows service? 10 seconds is not enough. I want 120 seconds.
RealTimeSync as Windows Service idle Time
In the RTS GUI you drag/drop your FFS sync configuration (a *.ffs_batch file you created) or specify your locations to be monitored and the command line invoking FFS to run the specified *.ffs_batch file) and you select a suitable RTS Idle time, and then save the RTS configuration as a *.ffs_real file.
Next, via the Task Scheduler or the autostart folder, you then invoke RTS, specifying the saved *.ffs_real file.
