Hello
I want to sync a folder locally from an FTP server. There is a problem logging in. The username contains a space. For example "Firstname Lastname". Can I set something in the software or does the FTP admin have to change the user name?
Thank you for your feedback and support.
FTP - Problem Username with space
The space character should not be a problem for FTP usernames in FreeFileSync.
Thank you for your feedback. In Name is also the leter "ä". Is ist possible that this leter makes the problem. With an another Tool, i have no login problems.
"ä" is ambiguous, it can encode to precomposed, or decomposed UTF8. What OS are you using FFS on?
I use a Microsoft Server 2016 Standard
I'd suggest you do a few tests with different user names. Most likely the space is the problem. AFAIK many FTP servers don't allow this. Perhaps the clients you've tested with internally replace space with "_".
