Hi folks,
I'm getting the following errors since upgrading to FFS 12. It happens with basic 12.0 and the Donation Edition.
/home/john/live_files/software/scripts/run_FFS: line 709: 13661 Segmentation fault (core dumped)
./FreeFileSync $FFS_batch_path/archive_primary.ffs_batch 2>> $BASH_logfile
run_FFS: archive_primary return_code = 139
Apart from the errors everything looks OK. The errors occur after each batch .ffs has been processed - the synchronisation seems to copy/delete files as expected and the script continues to run to conclusion.
I can zip any/all of the six CrashDump files if that will be of assistance.
Regards,
John
FreeFileSync 12.0 return code 139 - segmentation error
I was able to reproduce the crash. Fixed! Just download the current version 12.0 again.
Thanks Zenju. I have to go out now so I'll download it a bit later.
Hi Zenju,
I downloaded both the basic 12.0 and the Download Edition. I can confirm that they both run without error.
Thanks again.
John
Thanks again.
John
