Merging two folders into a third folder
Iridium
I'd like to compare two folders and their content by date and time.
Instead of afterwards updating one or two of the folders, I'd like to make FreeFileSync copy to a third folder which contains all files; that should be
• the files that are equal on both sides (only one copy of course)
• files that only appear in one of the sources
• in case of a date conflict: the newer file.
In my understanding that would be a two-way-synchronisation with the only difference that the source folders should stay original; the two-way-sync-result would point to a new folder.
Is this possible with FreeFileSync?
You could just do two 'updates', A to C and B to C
Iridium
Worked perfectly, thank you!
