I'm comparing two folders, one on my windows notebook and one on a shared folder on a linux server via samba.
The compare command return me no actions to do: it seems that the two folders are equals but, for example, in one of the subfolders in the main folder (that on the linux server) are 4 more files than than on my notebook.
What or where can I check?
Thanks.
Gigi
Compare error in v 2.1
Hi Gigi,
can you send me the *.ffs_gui xml file containing your configuration as well as the names of the files which were not found so that I can have a look?
Thanks, Zenju
Thanks, Zenju
Hi Gigi,
I think I've found the problem:
In your *.ffs_gui file one directory is called:
\\LINUX\disco\Company\Documenti Gigi\ArcaPro\_Clienti\Professional\Paradigma
but on the screenshot you are looking at:
\\linux\disco\Company\Clienti\Arca\Professional\Paradigma
So you were looking at a different directory than you were synchronizing. This should explain why some files were "missing".
Best regards, Zenju
Best regards, Zenju
Yes, it's all ok.I'm comparing two folders, one on my windows notebook and one on a shared folder on a linux server via samba.
Thanks.
Gigigigibi
Sorry for the mistake, this thing has made me crazy...
Sorry again and thanks.
Gigi
