Deleting sync history
GlenmorilTask
If I would like to remove the sync link between 2 different folders, do I just delete the DB file in both?
Is there an actual way to remove the link through the FFS ui?
What is a sync link? FFS doesn't 'link' anything. What is the goal you are trying to achieve?
GlenmorilTask
What is a sync link? FFS doesn't 'link' anything. What is the goal you are trying to achieve? xCSxXenon, 21 Feb 2023, 17:11
When two way sync is clicked, sync.ffs_db is created on both the DAS's folder and the local folder. If this does not 'link' the folders then what is its purpose?
On why and how the ffs database files are used, see e.g. here and (although described in another context) here.
