another multiple base conflict case?
patrickdrd
hello,
I'm getting the known message after adding these lines:
exclude:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\language</Item>
include:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\language\resource.language.en_gb</Item>
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\language\resource.language.en_us</Item>
exclude:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\resources\language</Item>
include:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\resources\language\English</Item>
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\resources\language\English (US)</Item>
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\resources\language\resource.language.en_gb</Item>
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\*\resources\language\resource.language.en_us</Item>
exclude:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\webinterface.default\lang</Item>
include:
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\webinterface.default\lang\en</Item>
<Item>\PortableApps\KodiPortable\App\Kodi*\addons\webinterface.default\lang\_strings\en.json</Item>
exclude:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\language</Item>
include:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\language\English</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\language\English (US)</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\language\resource.language.en_gb</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\language\resource.language.en_us</Item>
exclude:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\lib\pycountry\locales</Item>
include:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\lib\pycountry\locales\en</Item>
exclude:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\resources\language</Item>
include:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\resources\language\English</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\*\resources\language\English (US)</Item>
exclude:
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\packages</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\addons\temp</Item>
<Item>\PortableApps\KodiPortable\Data\portable_data\userdata\Thumbnails</Item>
they seem normal to me, I only want to sync english language, that's why
Not sure what you mean by
> I'm getting the known message ...
Which message do you get?
What do you mean by
> ... adding these lines
Do you manually edit the *.ffs_gui or *ffs_batch file with a text editor?
It is normally much easier and reliable to make changes to your Include and/or Exclude Filter in the FFS GUI.
Are your grouped entries for individual left-right folder pairs?
Particularly relevant here is if you still have the default entry * in your Include Filter or not.
Your entries don't seem to make sense as e.g. you Exclude
and then try to Include e.g.
The above Include definition is part of what is Excluded just above it, and will therefore not be synced.
It seems you can remove all the Exclude definitions, and just use all your Include definitions (but make sure to delete the default * entry in the Include Filter.)
patrickdrd
it's two different pairs,
the first is set to include * on the parent folder and exlude these folders,
and the other to include only the specific english language files ;)
