RealTimeSync question
quizhead
Hi all,
Is it possible to intialize multiple reat time syncs?
For example :
I want to sync drive C to drive D
At the same time I want to sync a specific folder in drive D to drive E.
Is it possible?
Thank you.
Yes
quizhead
Do you know how to set up a single RTS config?
If so, just do it multiple times
quizhead
If so, just do it multiple times xCSxXenon, 26 Feb 2023, 16:53
I understand but it doesn't seem that I can do multiple RTS in the same config windows.
Or am I wrong?
Ah yes, you are correct. You will have to create multiple RTS configs and they all run independently.
This may be confusing at first, but is actually best. This can prevent an issue with one config from causing all syncs to stall
quizhead
This may be confusing at first, but is actually best. This can prevent an issue with one config from causing all syncs to stall xCSxXenon, 26 Feb 2023, 17:35
Ok but how do this?
I can't for example open a windows to each RTS because there is only one.
Also, you can't devide RTS's in the same window.
You can open as many RTS sessions as you want, here I have four running. Just run RTS, create the config, save it, open another RTS, config that one, save it, etc
