Nice feature suggestion: Sync and eject
rin67630
First of all, a warm thank you for that great software !
I thought it were convenient and possibly easy to program an option "Sync and eject" that will eject the destination once copied. This were not only one step less for the user but would increase safety on the copied stick.
There are cmd utilities to eject USBs and they can be invoked using a post-sync command from FFS
