Is the NTFS attribute "A" (Archive) written/copied when syncing directories?
3453453453
I need to copy some larger folders. For a certain software it is relevant that the NTFS attribute "A" (Archive) is taken over during the sync.
From this post I understand that the archive bit is always taken over (viewtopic.php?t=7437), is that correct?
therube
FFS does not change attributes on copied files.
So, no, the archive bit is not cleared.
3453453453
Thanks!
