Synchronising is writing files to my hard drive
Quintin
I am mirroring 2 external drives, but when i run freefilesync, it seems to be writing files to my hard drive.
Why is it doing this - it is basically filling up my hard drive.
Thanks.
If you sync between two external drives, the only files that get written locally by FFS are:
* the global-settings file (GlobalSettings.xml)
* the log-file (normally in the users AppData\Roaming\FreeFileSync\Logs folder)
* and, if configured like that, files from Versioning
Quintin
these are my settings.
I don't know what else to check.
But when i hit synchronise, the space on my drive starts to decrease.
Share a screenshot of your paths in FFS
Run "Disk Inventory X" and see where the space is going
Quintin
Like this?
And can you explain what you mean by this?
Where do i run this?
It's a program that you download, it tells you where your space is being used
